Introduzione
Replace the eyepiece of the Canon PowerShot SX50 HS.
Cosa ti serve
Locate the battery compartment on the bottom of the camera.
Push the latch on the outside of the battery door to the right to get to the battery pack inside.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Remove the two #000 Phillips screws, length 2 mm, on the metal panel attaching the eyepiece to the rest of the camera.
Remove the two #000 Phillips screws, length 3 mm, attaching the metal panel to the eyepiece.
Altre 4 persone hanno completato questa guida.
