Salta al contenuto principale
Canon PowerShot SX260 HS Battery Replacement
Cosa ti serve
  1. Canon PowerShot SX260 HS Battery Replacement, Battery: passo 1, immagine 1 di 1
    • With the device fully assembled, hold the camera with both hands with the bottom of the camera facing toward you.
  2. Canon PowerShot SX260 HS Battery Replacement: passo 2, immagine 1 di 2 Canon PowerShot SX260 HS Battery Replacement: passo 2, immagine 2 di 2
    • Place your right thumb on the sliding panel that is marked Card/Battery
    • Slide the panel to your right and you will hear a slight click. This is normal and you did not damage the device.
  3. Canon PowerShot SX260 HS Battery Replacement: passo 3, immagine 1 di 1
    • Remove your thumb from the Card/Battery panel and lift the panel 90 degrees.
    • The battery will eject slightly by the force of a spring.
    • Remove the battery and replace.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,080
