Salta al contenuto principale
Canon PowerShot SX160 IS Function Wheel Replacement
Cosa ti serve
  1. Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: passo 1, immagine 1 di 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: passo 1, immagine 2 di 3 Canon PowerShot SX160 IS Function Wheel Replacement, Function Wheel: passo 1, immagine 3 di 3
    • Unscrew the 2-4.8mm black Phillips head screws from the front of the camera using a #0 Phillips screwdriver.
    • Unscrew the 2-4.8mm black Phillips head screws from the side of the camera using a #0 Phillips screwdriver.
    • Unscrew the 3-4.8mm black Phillips head screws from the bottom of the camera using a #0 Phillips screwdriver.
  2. Canon PowerShot SX160 IS Function Wheel Replacement: passo 2, immagine 1 di 2 Canon PowerShot SX160 IS Function Wheel Replacement: passo 2, immagine 2 di 2
    • Using your hands, gently separate the back panel from the camera.
    • Continue to pull the back panel until it completely detaches from the camera.
  3. Canon PowerShot SX160 IS Function Wheel Replacement: passo 3, immagine 1 di 2 Canon PowerShot SX160 IS Function Wheel Replacement: passo 3, immagine 2 di 2
    • Use a #0 phillips screwdriver to unscrew the 3-3.75mm silver Phillips head screws from the function wheel panel of the camera.
  4. Canon PowerShot SX160 IS Function Wheel Replacement: passo 4, immagine 1 di 1
    • Remove and replace the function wheel.
Conclusione
Congratulations, you have successfully replaced your function wheel. To reassemble your device, follow these instructions in reverse order.
Un commento
Hi, I replaced the LCD screen but now my function wheel and panel don’t work. I think the ribbon got disconnected , but I can’t figure out where to attach it. Can you help?
Denise Domian - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 620
