Salta al contenuto principale
Canon PowerShot SX150 IS Screen Replacement
Cosa ti serve
  1. Canon PowerShot SX150 IS Screen Replacement, Screen: passo 1, immagine 1 di 3 Canon PowerShot SX150 IS Screen Replacement, Screen: passo 1, immagine 2 di 3 Canon PowerShot SX150 IS Screen Replacement, Screen: passo 1, immagine 3 di 3
    • Remove the 2 outer 5mm screws using the size J000 screwdriver.
    • Remove the one 5mm screw on the left and the two 4mm screws on the bottom.
    • Remove the two 2mm screws located above the screen on the back of the camera.
  2. Canon PowerShot SX150 IS Screen Replacement: passo 2, immagine 1 di 3 Canon PowerShot SX150 IS Screen Replacement: passo 2, immagine 2 di 3 Canon PowerShot SX150 IS Screen Replacement: passo 2, immagine 3 di 3
    • Remove the plastic panel surrounding the screen. (it should pop off easily)
    • Remove the one 5mm screws on the right using the size J000 screw driver from the button plate. Remove the two 4mm screws on the left, then move the button plate out of the way.
    • carefully unlatch and then detach the button plat's flex ribbon from the motherboard.
  3. Canon PowerShot SX150 IS Screen Replacement: passo 3, immagine 1 di 1
    • Lift the flex ribbon lock gently with your finger.
  4. Canon PowerShot SX150 IS Screen Replacement: passo 4, immagine 1 di 2 Canon PowerShot SX150 IS Screen Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use the tweezers to carefully detach the screen’s flex ribbon from the circuit board.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
  5. Canon PowerShot SX150 IS Screen Replacement: passo 5, immagine 1 di 1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
  6. Canon PowerShot SX150 IS Screen Replacement: passo 6, immagine 1 di 1
    • Lift the screen out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 19
Tutti i Tempi: 733
