Salta al contenuto principale
Canon PowerShot SX150 IS Digital Image Sensor Replacement
Cosa ti serve
  1. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 1 di 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 2 di 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 3 di 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Canon PowerShot SX150 IS Prerequisite: passo 2, immagine 1 di 1
    • Remove the two 2mm screws above the screen using the size J000 screwdriver.
  3. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 3, immagine 1 di 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 3, immagine 2 di 2
    • Remove the two 5mm screws from the side of the camera with the J000 head screw driver.
    • Using the same screwdriver, remove the one 5mm screw from the other side of the camera located under the A/V Out flap.
  4. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 4, immagine 1 di 1
    • Remove two 4mm screws from the bottom of the camera with the J000 head screw driver.
  5. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 5, immagine 1 di 1
    • Remove the plastic panel surrounding the back screen.
  6. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 6, immagine 1 di 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 6, immagine 2 di 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the three 3mm screws using the size J000 screw driver from the button plate.
    • Gently flip up the flex ribbon lock and remove the flex ribbon using tweezers.
    • Move the button plate out of the way.
  7. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 7, immagine 1 di 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 7, immagine 2 di 2
    • There is a black flex ribbon lock that must be lifted and unlocked with your tweezers before this flex ribbon will detach.
    • Any small tear could ruin the flex ribbon. Be very gentle while removing it.
    • Gently lift the lock and detach the flex ribbon from the circuit board with the tweezers.
  8. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 8, immagine 1 di 1
    • Remove the two 2mm screws from the bottom of the screen with the size J000 screw driver.
    • You can then lift the screen out of place and set it aside.
  9. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 9, immagine 1 di 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 9, immagine 2 di 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 9, immagine 3 di 3
    • With the J000 Philips head screwdriver, remove the two 2mm screws from under the flash.
    • Using the same screwdriver, remove the two 5mm screws from the bottom. One is under the battery door.
    • With the same screwdriver, remove the 2mm screw at the top of the metal plate.
  10. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 10, immagine 1 di 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 10, immagine 2 di 2
    • Gently detach the flex ribbon with your tweezers before removing the front plate.
  11. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 11, immagine 1 di 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 11, immagine 2 di 3 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 11, immagine 3 di 3
    • Using the J000 Philips head screwdriver, remove the four 7mm screws from the silver panel.
    • Remove the two 5mm screws.
    • Remove the one 3 mm screw.
    • Using the same screwdriver, remove the 3mm screw from the top of the camera.
    • Pull the panel off and set it aside.
  12. Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: passo 12, immagine 1 di 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement, Digital Image Sensor: passo 12, immagine 2 di 2
    • Lift the two flex ribbons with your tweezers and remove them.
    • Move the circuit board to the side.
  13. Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 13, immagine 1 di 2 Canon PowerShot SX150 IS Digital Image Sensor Replacement: passo 13, immagine 2 di 2
    • Remove the three 2 mm screws from around the sensor.
    • Pull the sensor away.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 19
Tutti i Tempi: 962
