Salta al contenuto principale
Canon PowerShot SX150 IS Buttons Replacement
Cosa ti serve
  1. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 1 di 3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 2 di 3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 3 di 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
    Very useful information and pictures, although with a couple of omissions noted in the comments. (Kind of like getting a recipe from your favorite chef who always seems to leave out one or two of the key ingredients.)
    Eventually, if you go slowly, you will get all of the screws out. Just take pictures or make a drawing as you go along so that you know which screws go where when you reassemble. I learned quite a bit about what makes this lens jam and may not have to go quite so deep in to the camera the next time I’m trying to fix a jam.
    Phil Smith - Replica
  2. Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, immagine 1 di 3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, immagine 2 di 3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, immagine 3 di 3
    • Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
    • Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
  3. Canon PowerShot SX150 IS Buttons Replacement: passo 3, immagine 1 di 1
    • Remove the two, 4mm screws from the bottom of the camera. Continue using the same screwdriver from step 1.
  4. Canon PowerShot SX150 IS Buttons Replacement: passo 4, immagine 1 di 1
    • Remove back plate from the camera and locate the orange button plate to the right of the screen.
  5. Canon PowerShot SX150 IS Buttons Replacement: passo 5, immagine 1 di 3 Canon PowerShot SX150 IS Buttons Replacement: passo 5, immagine 2 di 3 Canon PowerShot SX150 IS Buttons Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Once the back plate is removed. Locate the buttons to the right of the screen.
    • Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
    • After lifting the tabs the buttons should come right off, then replace with the new button.
Conclusione
Un commento
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
robert jones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 609
