Salta al contenuto principale
Canon PowerShot SX150 IS Buttons Replacement
Cosa ti serve
  1. Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 1 di 3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 2 di 3 Canon PowerShot SX150 IS Buttons Replacement, Canon PowerShot SX150 IS Battery Removal: passo 1, immagine 3 di 3
    • Locate the battery cover on the bottom of the camera.
    • Slide the battery compartment cover the direction the arrow is pointing to open the compartment.
    • Remove batteries.
  2. Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, immagine 1 di 3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, immagine 2 di 3 Canon PowerShot SX150 IS Buttons Replacement, Buttons: passo 2, immagine 3 di 3
    • Remove the two, 2mm screws from the top of the screen. Using the J000 screwdriver.
    • Remove the 3, 5mm screws on either side of the camera. continue to use the same screwdriver from step 1.
  3. Canon PowerShot SX150 IS Buttons Replacement: passo 3, immagine 1 di 1
    • Remove the two, 4mm screws from the bottom of the camera. Continue using the same screwdriver from step 1.
  4. Canon PowerShot SX150 IS Buttons Replacement: passo 4, immagine 1 di 1
    • Remove back plate from the camera and locate the orange button plate to the right of the screen.
  5. Canon PowerShot SX150 IS Buttons Replacement: passo 5, immagine 1 di 3 Canon PowerShot SX150 IS Buttons Replacement: passo 5, immagine 2 di 3 Canon PowerShot SX150 IS Buttons Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Once the back plate is removed. Locate the buttons to the right of the screen.
    • Using the tweezers carefully lift up the tabs connecting the buttons to the button plate.
    • After lifting the tabs the buttons should come right off, then replace with the new button.
Conclusione
Un commento
Where do you buy replacement buttons/parts. Canon offers service but i don’t see parts?
robert jones - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 32
Tutti i Tempi: 625
