Strumenti
Parti
Nessuna parte specificata.
Turn the camera to the side that has the screen.
Unscrew the two black 3.4 mm screws with a #00 Phillips screwdriver.
Turn the camera with the lens facing down.
Use the blue opening tool to make lever. Insert the opening tool in the seam where the front case and the back case assemble.
Keep making pressure and slowly slide the opening tool through all the gap.
There is one point when the cover will disassemble completely.
Once you have removed the back cover this is what the camera will look like.
Locate the Control Dial.
