Salta al contenuto principale
Canon PowerShot SX120 IS Back Cover Replacement
Cosa ti serve
  1. Canon PowerShot SX120 IS Back Cover Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turning the camera so the screen is facing you.
    • Remove the two black 3.4 mm screws with a Phillips #00 screwdriver.
  2. Canon PowerShot SX120 IS Back Cover Replacement: passo 2, immagine 1 di 1
    • Put the camera with the lens facing up and turn it to the side so the DC IN A/V OUT DIGITAL is facing you.
    • Remove the single black 3.4 mm screw with a Phillips #00 screwdriver.
  3. Canon PowerShot SX120 IS Back Cover Replacement: passo 3, immagine 1 di 2 Canon PowerShot SX120 IS Back Cover Replacement: passo 3, immagine 2 di 2
    • Put the camera with the lens facing up, and turn it to the side where the battery cover is located.
    • Remove the three black 3.4 mm screws with a Phillips #00 screwdriver.
  4. Canon PowerShot SX120 IS Back Cover Replacement: passo 4, immagine 1 di 2 Canon PowerShot SX120 IS Back Cover Replacement: passo 4, immagine 2 di 2
    • Put the camera with the lens facing up, turn it to the side where the compartment of the battery (CR1220) for time/date is located.
  5. Canon PowerShot SX120 IS Back Cover Replacement: passo 5, immagine 1 di 1
    • Put the camera with the lens facing down, and turn it to the side where the DC IN A/V OUT DIGITAL cover and the silver lanyard attachment are located.
    • Open the DC IN A/V OUT DIGITAL cover.
  6. Canon PowerShot SX120 IS Back Cover Replacement: passo 6, immagine 1 di 3 Canon PowerShot SX120 IS Back Cover Replacement: passo 6, immagine 2 di 3 Canon PowerShot SX120 IS Back Cover Replacement: passo 6, immagine 3 di 3
    • Turn the camera with the lens facing down.
    • Opening the camera can be challenging. Don't get discouraged if it takes you a few tries before the camera is opened.
    • Use the iFixit opening tool to make leverage. Insert the opening tool in the seam where the front case and the back case assemble.
    • Carefully put pressure on the opening tool so the cover can gradually open.
    • Slowly slide the opening tool along the gap and around the edge of the camera.
    • When you are dissembling the back cover, the DC IN A/V OUT DIGITAL cover will also disassemble and fall off.
  7. Canon PowerShot SX120 IS Back Cover Replacement: passo 7, immagine 1 di 1
    • Remove the back cover and the DC IN A/V OUT DIGITAL cover from the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Maria
Membro da: 03/13/14
875 Reputazione
1 Guida realizzata
Un commento
It took me 2 hours to install the battery door. I dropped one screw and could not find it any more it just vanished.
I was lucky to find one just like the one I lost after a half hour search.All in all I did a pretty good good job for an
auto mechanic .Thanks very much for your help, it was very easy to follow your instructions.
Fred Czarnik
Frederick Czarnik - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,719
