Salta al contenuto principale
Canon PowerShot SD960 IS Battery Replacement
  1. Canon PowerShot SD960 IS Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the camera over so that the bottom of the camera is facing up.
  2. Canon PowerShot SD960 IS Battery Replacement: passo 2, immagine 1 di 2 Canon PowerShot SD960 IS Battery Replacement: passo 2, immagine 2 di 2
    • Apply slight pressure to the battery door and slide your finger over the release button in the direction of the arrows to open the battery door.
    • The battery door will open, allowing you to access the battery.
  3. Canon PowerShot SD960 IS Battery Replacement: passo 3, immagine 1 di 1
    • Push the the orange battery lock back to release the battery.
    • Remove the battery.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 462
