Introduzione
Use this guide to remove a broken Motherboard from your Canon PowerShot SD850 IS.
Cosa ti serve
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
Remove the 1.85 mm #00 Phillips located on the left side of the camera.
Use a spudger or a flathead screwdriver and carefully pry out the first flash cable from the bottom of the cable. The white 2 prong power cable pops UP (use spudger below red/black insertion and put upward pressure). For the yellow one, apply pressure horizontally.
Next use a spudger or a flathead screwdriver and carefully pry out the second flash cable.
Remove four screws located on the back of the camera:
6.15 mm #00 Phillips
2.75 mm #00 Phillips
2.15 mm #00 Phillips
2.7 mm #00 Phillips
Remove the 2.6 mm Phillips #00 located near the shutter release button.
