Introduzione
This manual is for replacing the function/set button located on the back of the camera.
Cosa ti serve
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
Remove the following 4 screws:
Two 2.8 mm Phillips #00 at the bottom of the camera.
Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
