Introduzione
How to remove/install the battery of your Canon PowerShot SD850 IS.
  1. Using your fingernail, slide the light gray tab towards edge of camera. Slide the light gray door and pull up to open the door. In the camera shown in the photos, there is not a Memory Card or Battery.
    • Using your fingernail, slide the light gray tab towards edge of camera.
    • Slide the light gray door and pull up to open the door.
    • In the camera shown in the photos, there is not a Memory Card or Battery.
    • Both Battery and Memory Card slots should be visible.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Use your fingernail and slide the small brown tab towards the edge of the camera. The battery will pop up.
    • Use your fingernail and slide the small brown tab towards the edge of the camera.
    • The battery will pop up.
    • Pull battery straight out of battery holder.
    • When putting the battery back in, make sure it the battery is oriented so the terminals connect.
Conclusione
Peter Tran
Membro da: 06/10/2010
225 Reputazione
6 Guide realizzate
Cal Poly, Team 20-7, Maness Fall 2010 Membro di Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,539
