Salta al contenuto principale
Canon PowerShot SD780 IS LCD Screen Replacement
Cosa ti serve
  1. Canon PowerShot SD780 IS LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Turn the camera off by pressing the power button.
    • Also, make sure the battery is removed, as to avoid any shock injuries. To remove the battery located at the bottom corner of the camera, slide the panel towards the corner. Push the orange tab upwards and remove the battery.
  2. Canon PowerShot SD780 IS LCD Screen Replacement: passo 2, immagine 1 di 2 Canon PowerShot SD780 IS LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove five screws from the camera casing using a Phillips #00 screwdriver.
    • There are two 2 mm screws located on the left side of the camera.
  3. Canon PowerShot SD780 IS LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the front panel of the camera case to expose the top left copper strip.
    • Gently pull the copper strip upward and disconnect it from the camera.
  4. Canon PowerShot SD780 IS LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the screw on the far left-hand side of the front of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot SD780 IS LCD Screen Replacement: passo 5, immagine 1 di 1
    • Carefully pull the case apart at the seam. The case will detach from the camera in two pieces.
  6. Canon PowerShot SD780 IS LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove the indicated "L" shaped bracket from around the bottom and right side of the LCD screen.
  7. Canon PowerShot SD780 IS LCD Screen Replacement: passo 7, immagine 1 di 1
    • Insert the flat side of your spudger tool carefully into the top of the LCD screen and lift the screen free.
    • Set the broken screen aside and place the new screen on top of the LCD screen.
Conclusione
Arlene Ale
Membro da: 03/13/14
455 Reputazione
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,346
