Salta al contenuto principale
Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement
Cosa ti serve
  1. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 2, immagine 1 di 2 Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 2, immagine 2 di 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement, Front and Rear Casing: passo 3, immagine 1 di 2 Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement, Front and Rear Casing: passo 3, immagine 2 di 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 4, immagine 1 di 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 5, immagine 1 di 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 6, immagine 1 di 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 7, immagine 1 di 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 8, immagine 1 di 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 9, immagine 1 di 2 Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 9, immagine 2 di 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
  10. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement, Button Contact Panel: passo 10, immagine 1 di 1
    • Carefully wedge the pry tool under the ribbon in the ribbon gate.
    • Gently remove the ribbon from the ribbon gate by pulling it away from the gate with the pry tool.
    • Be careful not to damage the ribbon.
  11. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 11, immagine 1 di 1
    • Gently press the ribbon back to get access to a Phillips screw behind it.
    • Unscrew two .125 inch long Phillips screws using a #00 Philips screwdriver.
  12. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 12, immagine 1 di 3 Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 12, immagine 2 di 3 Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 12, immagine 3 di 3
    • Remove the ribbon with a pry tool by gently pulling it out of the ribbon gate tab.
    • Pull the button board away from the rest of the camera.
  13. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement, LCD: passo 13, immagine 1 di 1
    • Unscrew one .113 inch Phillips screw using a #00 Phillips screwdriver.
  14. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 14, immagine 1 di 1
    • Lift the LCD screen up and away from the tab that holds it in place on the face of the camera.
    • Be careful, the LCD screen is still connect to the camera by a ribbon cable.
  15. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 15, immagine 1 di 2 Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 15, immagine 2 di 2
    • Gently press the pry tool under the ribbon gate and lift up to free the ribbon connecting the LCD to the circuit board.
    • The LCD can now be completely removed from the camera.
  16. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement, Image Sensor: passo 16, immagine 1 di 1
    • Place the pry tool under ribbon gate and gently lift it up, disconnecting the ribbon.
  17. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 17, immagine 1 di 1
    • Unscrew three .15 inch Phillips screws from the back of the camera using a #00 Phillips screwdriver.
  18. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 18, immagine 1 di 2 Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 18, immagine 2 di 2
    • Use the pry tool to gently lift the image sensor away from the rest of the camera.
    • Be careful not to damage the image sensor as you pry it up.
  19. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement, Flash Bulb Assembly: passo 19, immagine 1 di 1
    • Arrange camera so it is facing up towards you.
    • Unscrew one .01 inch Phillips screw using a #00 Phillips screwdriver from the front of the camera.
  20. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 20, immagine 1 di 1
    • Gently remove the indicated ribbon from respective ribbon gates.
  21. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 21, immagine 1 di 1
    • Place spudger under white connector and gently lift it vertically out of its slot.
    • Be careful not to damage wire connector during removal.
  22. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 22, immagine 1 di 1
    • Unscrew three .065 inch Phillips screws using a #00 Phillips screwdriver from the back of the camera.
  23. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 23, immagine 1 di 1
    • Gently pull away flash bulb assembly from the rest of the camera.
    • Be careful not to damage the ribbon on the rest of the camera.
  24. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement, Zoom Lens Assembly: passo 24, immagine 1 di 1
    • Unscrew three .12 inch long Phillips screws using a #00 Phillips screwdriver from the back of the camera.
  25. Canon PowerShot SD500 Digital ELPH Zoom Lens Assembly Replacement: passo 25, immagine 1 di 1
    • Gently remove zoom lens from the rest of the camera.
    • Be careful not to damage ribbon during removal.
Conclusione
Clemson, Team 2-1, Benson Fall 2014 Membro di Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 893
