Salta al contenuto principale
Canon PowerShot SD30 Screen Replacement
Cosa ti serve
  1. Canon PowerShot SD30 Screen Replacement, Front Cover: passo 1, immagine 1 di 2 Canon PowerShot SD30 Screen Replacement, Front Cover: passo 1, immagine 2 di 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Screen Replacement: passo 2, immagine 1 di 1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Screen Replacement, Back Cover: passo 3, immagine 1 di 3 Canon PowerShot SD30 Screen Replacement, Back Cover: passo 3, immagine 2 di 3 Canon PowerShot SD30 Screen Replacement, Back Cover: passo 3, immagine 3 di 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Screen Replacement: passo 4, immagine 1 di 1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Screen Replacement, Screen: passo 5, immagine 1 di 2 Canon PowerShot SD30 Screen Replacement, Screen: passo 5, immagine 2 di 2
    • Remove top button panel by removing the screw located at the top right of the panel.
  6. Canon PowerShot SD30 Screen Replacement: passo 6, immagine 1 di 2 Canon PowerShot SD30 Screen Replacement: passo 6, immagine 2 di 2
    • Remove screws both at the top and the base of the screen to free the screen.
  7. Canon PowerShot SD30 Screen Replacement: passo 7, immagine 1 di 3 Canon PowerShot SD30 Screen Replacement: passo 7, immagine 2 di 3 Canon PowerShot SD30 Screen Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to lift the tab that secures the screen wire and remove.
    • You need to do this for both wires.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 154
