Salta al contenuto principale
Canon PowerShot SD1300 IS Lens Replacement
Cosa ti serve
  1. Canon PowerShot SD1300 IS Lens Replacement, Lens: passo 1, immagine 1 di 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: passo 1, immagine 2 di 3 Canon PowerShot SD1300 IS Lens Replacement, Lens: passo 1, immagine 3 di 3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
    • Remove a single 2mm J00 screw on the left exterior hidden under the A/V Out port.
  2. Canon PowerShot SD1300 IS Lens Replacement: passo 2, immagine 1 di 1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Lens Replacement: passo 3, immagine 1 di 1
    • Use one of your plastic opening tools to separate the screen from the main body of your PowerShot.
  4. Canon PowerShot SD1300 IS Lens Replacement: passo 4, immagine 1 di 1
    • Remove five of the 3mm J00 screws under the screen to release the lens for replacement.
    • Lens assembly should be removed through the front of the camera once screws are removed.
Conclusione
Altre 2 persone hanno completato questa guida.
Clayton
Membro da: 03/20/17
560 Reputazione
5 Guide realizzate
Un commento
I have a SD1300 IS and it has another case screw beneath a plastic cover just below the USB port.
Also step 4 shows 2 screws to remove on the lens that do not go through the metal frame. These should not be removed for lens removal.
It is necessary on mine to remove the 2 screws on the left side of the metal frame that attach to the lens assy.
Greg Reinhart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 39
Tutti i Tempi: 1,293
