Salta al contenuto principale
Canon PowerShot SD1300 IS Flash Assembly Replacement
Cosa ti serve
  1. Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: passo 1, immagine 1 di 3 Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: passo 1, immagine 2 di 3 Canon PowerShot SD1300 IS Flash Assembly Replacement, Flash Assembly: passo 1, immagine 3 di 3
    • Remove the two 2mm J00 screws on the right exterior.
    • Remove a single 4 mm J00 on the bottom exterior.
    • Remove a single 3mm J00 on the left exterior.
  2. Canon PowerShot SD1300 IS Flash Assembly Replacement: passo 2, immagine 1 di 1
    • Once the front shell of the camera is removed the back shell should slide off just the same.
  3. Canon PowerShot SD1300 IS Flash Assembly Replacement: passo 3, immagine 1 di 1
    • Remove a 3mm J00 screw from behind wires under the flash.
  4. Canon PowerShot SD1300 IS Flash Assembly Replacement: passo 4, immagine 1 di 1
    • Use plastic opening tool to remove the screen to gain access to the screws to remove the Flash Assembly.
  5. Canon PowerShot SD1300 IS Flash Assembly Replacement: passo 5, immagine 1 di 1
    • Remove the two 3mm J00 screws under the screen.
    • Remove the 4mm J00 screws under the screen.
    • The flash assembly is now released and should be able to be removed from the front side of the camera.
Conclusione
Clayton
Membro da: 03/20/17
560 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 20
Tutti i Tempi: 360
