Salta al contenuto principale
Canon PowerShot SD1200 IS Motherboard
Cosa ti serve
  1. Canon PowerShot SD1200 IS Motherboard, Front and Rear Covers: passo 1, immagine 1 di 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Motherboard: passo 2, immagine 1 di 3 Canon PowerShot SD1200 IS Motherboard: passo 2, immagine 2 di 3 Canon PowerShot SD1200 IS Motherboard: passo 2, immagine 3 di 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Motherboard: passo 3, immagine 1 di 2 Canon PowerShot SD1200 IS Motherboard: passo 3, immagine 2 di 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Motherboard, Motherboard: passo 4, immagine 1 di 1
    • Remove the microphone connector by gripping it with the tool and gently, with a wiggling motion, pull it out.
    • Pull the connector straight out by the white connector. Pulling on the wires will damage them.
  5. Canon PowerShot SD1200 IS Motherboard: passo 5, immagine 1 di 1
    • Lift off the mechanical shutter button assembly.
  6. Canon PowerShot SD1200 IS Motherboard: passo 6, immagine 1 di 2 Canon PowerShot SD1200 IS Motherboard: passo 6, immagine 2 di 2
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the bottom of the motherboard.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable.
    • Use the spudger to pry up each side of the Flat-Topped Connectors
  7. Canon PowerShot SD1200 IS Motherboard: passo 7, immagine 1 di 1
    • Remove the press fit ribbon cable by prying upward with spudger tool.
    • It is not necessary to remove the Lens or Flash Assemblies to remove the motherboard.
  8. Canon PowerShot SD1200 IS Motherboard: passo 8, immagine 1 di 1
    • Remove the bottom right screw from the motherboard. (4mm Phillips 00)
    • Remove top and lower left black screws from the motherboard. (2.5mm Phillips 00)
  9. Canon PowerShot SD1200 IS Motherboard: passo 9, immagine 1 di 1
    • Lift out the motherboard.
Conclusione
Jeff Casper
Membro da: 09/15/16
848 Reputazione
7 Guide realizzate
USF Tampa, Team 17-5, Blackwell Fall 2016 Membro di USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 400
