Salta al contenuto principale
Canon PowerShot SD1200 IS Function Button Board Replacement
Cosa ti serve
  1. Canon PowerShot SD1200 IS Function Button Board Replacement, Front and Rear Covers: passo 1, immagine 1 di 1
    • Remove the battery.
  2. Canon PowerShot SD1200 IS Function Button Board Replacement: passo 2, immagine 1 di 3 Canon PowerShot SD1200 IS Function Button Board Replacement: passo 2, immagine 2 di 3 Canon PowerShot SD1200 IS Function Button Board Replacement: passo 2, immagine 3 di 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  3. Canon PowerShot SD1200 IS Function Button Board Replacement: passo 3, immagine 1 di 2 Canon PowerShot SD1200 IS Function Button Board Replacement: passo 3, immagine 2 di 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
  4. Canon PowerShot SD1200 IS Function Button Board Replacement, Function Buttons: passo 4, immagine 1 di 1
    • Use the spudger to lift the tab on the Zero Insertion Force (ZIF) connector located at the top of the function button board.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
    • Slide out the ribbon cable from the connector.
  5. Canon PowerShot SD1200 IS Function Button Board Replacement: passo 5, immagine 1 di 1
    • Remove the top screw from the function button board. (3.5mm Phillips 00)
    • Remove the bottom screw from the function button board. (2.5mm Phillips 00)
  6. Canon PowerShot SD1200 IS Function Button Board Replacement: passo 6, immagine 1 di 1
    • Lift out the function button board.
Conclusione
Jeff Casper
Membro da: 09/15/16
897 Reputazione
7 Guide realizzate
USF Tampa, Team 17-5, Blackwell Fall 2016 Membro di USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 418
