Salta al contenuto principale
Canon PowerShot SD1100 IS Top Button Assembly Replacement
Cosa ti serve
  1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: passo 1, immagine 1 di 2 Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: passo 1, immagine 2 di 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 2, immagine 1 di 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 2, immagine 2 di 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 2, immagine 3 di 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 3, immagine 1 di 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 3, immagine 2 di 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 3, immagine 3 di 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 4, immagine 1 di 1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Top Button Assembly: passo 5, immagine 1 di 1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 6, immagine 1 di 1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 7, immagine 1 di 1
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Top Button Assembly Replacement: passo 8, immagine 1 di 1
    • The shutter button assembly should now be removed.
Conclusione
Wyatt Chan
Membro da: 01/05/11
235 Reputazione
2 Guide realizzate
Cal Poly, Team 3-32, Regan Winter 2011 Membro di Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,060
