Salta al contenuto principale
Canon PowerShot SD1100 IS Function Buttons Replacement
Cosa ti serve
  1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: passo 1, immagine 1 di 2 Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: passo 1, immagine 2 di 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 2, immagine 1 di 3 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 2, immagine 2 di 3 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 2, immagine 3 di 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 3, immagine 1 di 3 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 3, immagine 2 di 3 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 3, immagine 3 di 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 4, immagine 1 di 1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: passo 5, immagine 1 di 1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 6, immagine 1 di 1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 8, immagine 1 di 1
    • The shutter button assembly should now be removed.
  9. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: passo 9, immagine 1 di 1
    • With the spudger, flip up the black tab on the main ribbon.
  10. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 10, immagine 1 di 2 Canon PowerShot SD1100 IS Function Buttons Replacement: passo 10, immagine 2 di 2
    • Gently pull straight out on the ribbon to disconnect it from the logic board.
  11. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 11, immagine 1 di 1
    • By hand, gently unfold the function button board and lift it off the frame.
  12. Canon PowerShot SD1100 IS Function Buttons Replacement: passo 12, immagine 1 di 1
    • Congratulations! The function button board can now be replaced.
Conclusione
Wyatt Chan
Membro da: 01/05/11
235 Reputazione
2 Guide realizzate
Cal Poly, Team 3-32, Regan Winter 2011 Membro di Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,094
