Salta al contenuto principale
Canon PowerShot SD1000 Motherboard Replacement
Cosa ti serve
  1. Canon PowerShot SD1000 Motherboard Replacement, Back Panel: passo 1, immagine 1 di 2 Canon PowerShot SD1000 Motherboard Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Motherboard Replacement: passo 4, immagine 1 di 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Motherboard Replacement, Front Case: passo 6, immagine 1 di 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Motherboard Replacement: passo 7, immagine 1 di 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Motherboard Replacement, LCD Screen: passo 8, immagine 1 di 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Motherboard Replacement: passo 9, immagine 1 di 2 Canon PowerShot SD1000 Motherboard Replacement: passo 9, immagine 2 di 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Motherboard Replacement: passo 10, immagine 1 di 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Motherboard Replacement: passo 11, immagine 1 di 2 Canon PowerShot SD1000 Motherboard Replacement: passo 11, immagine 2 di 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Motherboard Replacement: passo 12, immagine 1 di 3 Canon PowerShot SD1000 Motherboard Replacement: passo 12, immagine 2 di 3 Canon PowerShot SD1000 Motherboard Replacement: passo 12, immagine 3 di 3
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Motherboard Replacement, Flash Unit: passo 13, immagine 1 di 2 Canon PowerShot SD1000 Motherboard Replacement, Flash Unit: passo 13, immagine 2 di 2
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Motherboard Replacement: passo 14, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Motherboard Replacement: passo 15, immagine 1 di 1
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Motherboard Replacement: passo 16, immagine 1 di 2 Canon PowerShot SD1000 Motherboard Replacement: passo 16, immagine 2 di 2
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
  17. Canon PowerShot SD1000 Motherboard Replacement, Shutter Button: passo 17, immagine 1 di 2 Canon PowerShot SD1000 Motherboard Replacement, Shutter Button: passo 17, immagine 2 di 2
    • Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
  18. Canon PowerShot SD1000 Motherboard Replacement, Lens: passo 18, immagine 1 di 1
    • Remove the 2.90mm screw from the lens, near the motherboard.
  19. Canon PowerShot SD1000 Motherboard Replacement: passo 19, immagine 1 di 2 Canon PowerShot SD1000 Motherboard Replacement: passo 19, immagine 2 di 2
    • Using the spudger remove the shutter button by prying the small tab on the front side of the camera.
  20. Canon PowerShot SD1000 Motherboard Replacement: passo 20, immagine 1 di 2 Canon PowerShot SD1000 Motherboard Replacement: passo 20, immagine 2 di 2
    • With a spudger disconnect the orange connector ribbon as shown.
    • Disconnect the orange connector ribbon that is located under the now removed shutter button.
  21. Canon PowerShot SD1000 Motherboard Replacement: passo 21, immagine 1 di 1
    • Remove the two 2.90 mm screws from the motherboard.
  22. Canon PowerShot SD1000 Motherboard Replacement: passo 22, immagine 1 di 1
    • With Tweezers detach the bottom orange ribbon.
  23. Canon PowerShot SD1000 Motherboard Replacement: passo 23, immagine 1 di 1
    • Remove the screws shown. Start with the outside 6 (3-2.90mm & 3-2.40mm) screws on the metal frame. Then remove the 6 (2.40mm) screws on the back of the lens piece
  24. Canon PowerShot SD1000 Motherboard Replacement: passo 24, immagine 1 di 1
    • With spudger gently remove the Viewfinder Window that is directly above the lens.
  25. Canon PowerShot SD1000 Motherboard Replacement: passo 25, immagine 1 di 3 Canon PowerShot SD1000 Motherboard Replacement: passo 25, immagine 2 di 3 Canon PowerShot SD1000 Motherboard Replacement: passo 25, immagine 3 di 3
    • Detach the mother board with lens from body of camera.
    • Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
    • Your lens has been removed from the motherboard and bottom framing.
  26. Canon PowerShot SD1000 Motherboard Replacement, Motherboard: passo 26, immagine 1 di 1
    • The motherboard (left) is now separated from the lens.
Conclusione
Cal Poly, Team 8-18, Maness Winter 2012 Membro di Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Membri
12 Guide realizzate
Un commento
Which part is the CCD sensor?
yakksoho - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 42
Tutti i Tempi: 6,652
