Parti
Nessuna parte richiesta.
Remove the two screws from the side panel closest to the camera lens.
  • Remove the two screws from the side panel closest to the camera lens.
  • Note: These screws are 2.9 mm long.
Aggiungi Commento
Remove the two screws from the camera bottom panel.
  • Remove the two screws from the camera bottom panel.
Aggiungi Commento
  • Remove the 2 screws from the side panel farthest from the lens.
Aggiungi Commento
  • Pull the back panel away from the camera body, starting at the end with the function buttons.
Aggiungi Commento
  • Remove the small cover panel and attached wrist strap mount.
Aggiungi Commento
  • Remove the front cover by gently pulling it away from the camera body.
Aggiungi Commento
  • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Aggiungi Commento
  • Remove the 2 screws located at the top of the LCD panel.
  • Note: These screws are 2.4 mm long.
Aggiungi Commento
  • Pull up the metal frame surrounding LCD screen starting at the side of the camera.
Aggiungi Commento
  • Push the metal frame away from the metal tab using the spudger, to detach the frame.
  • Rotate the metal frame upwards.
  • Note: The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
Aggiungi Commento
  • Carefully lift the metal frame from the camera.
  • Remove the black LCD screen, leaving the thin lens pieces in place.
  • Note: BE CAREFUL, both components are attached by an orange connector ribbon and cannot be removed yet!
Aggiungi Commento
  • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
  • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
  • Note: Tweezers are helpful to disconnect the ribbon
Aggiungi Commento
  • Remove the metal frame on the side closest to the flash mechanism. This will expose the screw securing the flash assembly.
Aggiungi Commento
  • Remove the screw securing the flash assembly.
  • Note: The screw is 2.4mm long.
Aggiungi Commento
  • Use the spudger to carefully disconnect the flash assembly ribbon from the black connector lock.
Aggiungi Commento
  • Remove the flash assembly.
  • Note: BE CAREFUL, when handling the flash assembly; touching the capacitor (the black cylinder) could shock you
Aggiungi Commento
  • Remove the 2.90mm screw from the lens, near the motherboard.
Aggiungi Commento
  • Using the spudger remove the shutter button by prying the small tab on the front side of the camera.
Aggiungi Commento
  • With a spudger disconnect the orange connector ribbon as shown.
  • Disconnect the orange connector ribbon that is located under the now removed shutter button.
Aggiungi Commento
  • Remove the two 2.90 mm screws from the motherboard.
Aggiungi Commento
  • With Tweezers detach the bottom orange ribbon.
Aggiungi Commento
  • Remove the screws shown. Start with the outside 6 (3-2.90mm & 3-2.40mm) screws on the metal frame. Then remove the 6 (2.40mm) screws on the back of the lens piece
Aggiungi Commento
  • With spudger gently remove the Viewfinder Window that is directly above the lens.
Remove screw attaching viewfinder piece to lens framing.
Adam Biesok - Replica
  • Detach the mother board with lens from body of camera.
  • Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
  • Your lens has been removed from the motherboard and bottom framing.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Phillip Phung
Membro da: 19/01/2012
486 Reputazione
9 Guide realizzate
Cal Poly, Team 8-18, Maness Winter 2012 Membro di Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,517
