Salta al contenuto principale
Canon PowerShot S500 Front and Rear Casing Replacement
Cosa ti serve
  1. Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : passo 1, immagine 1 di 2 Canon PowerShot S500 Front and Rear Casing  Replacement, Front and Rear Casing : passo 1, immagine 2 di 2
    • Unscrew five Phillips screws using a #0 Phillips screwdriver.
    • One screw is on upper right corner of the back panel.
    • The other four screws are on the bottom of the camera.
  2. Canon PowerShot S500 Front and Rear Casing  Replacement: passo 2, immagine 1 di 1
    • Open the memory card cover by moving the slide switch toward the top end of of the camera.
    • Remove the memory card from the slot.
  3. Canon PowerShot S500 Front and Rear Casing  Replacement: passo 3, immagine 1 di 1
    • Remove the rear cover from the rest of the camera.
    • This may require gentle rocking of the case to free it.
  4. Canon PowerShot S500 Front and Rear Casing  Replacement: passo 4, immagine 1 di 2 Canon PowerShot S500 Front and Rear Casing  Replacement: passo 4, immagine 2 di 2
    • Unscrew the four Phillips screws from the side of the casing and one screw from the bottom using a #0 Phillips screwdriver.
  5. Canon PowerShot S500 Front and Rear Casing  Replacement: passo 5, immagine 1 di 1
    • Free the front cover from the rest of the camera.
    • The cover may require gentle rocking to remove.
Linea Traguardo
Cal Poly, Team 16-28, Maness Winter 2010 Membro di Cal Poly, Team 16-28, Maness Winter 2010
CPSU-MANESS-W10S16G28
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,627
