Introduzione
This guide shows you how to remove the motherboard battery and replace it with a new one.
Cosa ti serve
Locate the panel labeled "Batt. Open"
Place your finger on the panel and slide it in the direction of the arrow.
The slot will swing open revealing the battery pack.
Using the Phillips #0 screwdriver, remove the 3.8mm screw in the upper right corner.
Remove the two 2.3mm outer screws using the Phillips #0 screwdriver.
Remove the two 3.8mm screws near the strap bracket.
Remove the small panel covering the mounting bracket.
Remove the door covering the memory card.
Remove the plastic flap covering the motherboard.
Place edge of iPod Opening Tool in the small opening between the battery and the motherboard.
Pry the battery off of the motherboard using the iPod Opening Tool.
