Salta al contenuto principale
Canon PowerShot S400 Shutter Button Assembly Replacement
Cosa ti serve
  1. Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: passo 1, immagine 1 di 2 Canon PowerShot S400 Shutter Button Assembly Replacement, Shutter Button Assembly: passo 1, immagine 2 di 2
    • Unless otherwise stated,a #00 philips screwdriver will be used to remove screws.
    • Remove the 4.75mm screw located in the top right corner of the backside of the camera.
    • Remove the four # screws located on the bottom of the camera.
  2. Canon PowerShot S400 Shutter Button Assembly Replacement: passo 2, immagine 1 di 3 Canon PowerShot S400 Shutter Button Assembly Replacement: passo 2, immagine 2 di 3 Canon PowerShot S400 Shutter Button Assembly Replacement: passo 2, immagine 3 di 3
    • Remove the two screws located on the right side of the camera.(the side with the USB adaption plug)
    • Remove the four screws on the left side of the camera.
    • This will release a small metal plate. Remove this plate.
  3. Canon PowerShot S400 Shutter Button Assembly Replacement: passo 3, immagine 1 di 3 Canon PowerShot S400 Shutter Button Assembly Replacement: passo 3, immagine 2 di 3 Canon PowerShot S400 Shutter Button Assembly Replacement: passo 3, immagine 3 di 3
    • There is a small black plastic piece that sits above the lens underneath the camera case. This plastic piece may fall out when you remove the cases; recover the piece and save it.
    • Now separate the front and back camera casings.
  4. Canon PowerShot S400 Shutter Button Assembly Replacement: passo 4, immagine 1 di 1
    • Using a spudger, carefully pry the shutter button assembly from the camera.
    • Install the replacement shutter button assembly.
Conclusione
Ross Bryan
Membro da: 01/21/11
375 Reputazione
3 Guide realizzate
Cal Poly, Team 5-19, Amido Winter 2011 Membro di Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,847
