Salta al contenuto principale
Canon PowerShot S400 Motherboard Replacement
Cosa ti serve
  1. Canon PowerShot S400 Motherboard Replacement, LCD Screen: passo 1, immagine 1 di 2 Canon PowerShot S400 Motherboard Replacement, LCD Screen: passo 1, immagine 2 di 2
    • Unless stated otherwise, use a Phillips #00 screwdriver to remove all screws.
    • On the backside of the camera, remove the 4.75 mm screw that sits at the top right corner.
    • Remove the four 4.75 mm screws that sit at the bottom of the camera.
  2. Canon PowerShot S400 Motherboard Replacement: passo 2, immagine 1 di 1
    • On the side of the camera, remove the two 4.75 mm screws that sit near the USB digital terminal.
  3. Canon PowerShot S400 Motherboard Replacement: passo 3, immagine 1 di 3 Canon PowerShot S400 Motherboard Replacement: passo 3, immagine 2 di 3 Canon PowerShot S400 Motherboard Replacement: passo 3, immagine 3 di 3
    • On the side of the camera, remove the four 4.75 mm screws that sit near the wrist strap mount.
    • Remove the two small metal plates, which the four screws hold in place.
  4. Canon PowerShot S400 Motherboard Replacement: passo 4, immagine 1 di 2 Canon PowerShot S400 Motherboard Replacement: passo 4, immagine 2 di 2
    • When removing the casing, do not drop the small black plastic piece. This piece sits in a small gap above the lens, to the left of the flash, and underneath the camera case.
    • Remove the small black plastic piece and set it aside. If necessary, use tweezers to remove the small black plastic piece.
    • Detach the front case and back case.
  5. Canon PowerShot S400 Motherboard Replacement: passo 5, immagine 1 di 1
    • Do not remove the metal plate this step refers to. Removal at this step may damage the ribbon cable. Wait until the next step to remove the plate.
    • Remove the 3.5 mm screw that sits on the metal plate at the bottom of the camera.
    • Remove the two other 3.5 mm screws that sit on the side, to the left of the screw you just removed.
    • In the image, we have already removed some of the screws.
  6. Canon PowerShot S400 Motherboard Replacement: passo 6, immagine 1 di 3 Canon PowerShot S400 Motherboard Replacement: passo 6, immagine 2 di 3 Canon PowerShot S400 Motherboard Replacement: passo 6, immagine 3 di 3
    • A ribbon cable attaches to the metal plate and to the main circuit board, on the front of the camera.
    • Gently release the black latch.
    • Remove the ribbon cable and metal plate assembly.
  7. Canon PowerShot S400 Motherboard Replacement: passo 7, immagine 1 di 2 Canon PowerShot S400 Motherboard Replacement: passo 7, immagine 2 di 2
    • On the backside of the camera, remove the 3.5 mm screw that sits to the left of the viewfinder and above the LCD screen.
    • Remove the second 3.5 mm screw that sits directly above the LCD screen.
    • Gently detach the ribbon cable.
  8. Canon PowerShot S400 Motherboard Replacement: passo 8, immagine 1 di 1
    • Locate the ribbon cable on the main circuit board, which sits below the lens.
    • Gently release the black latch on the ribbon cable connector and detach the ribbon cable.
  9. Canon PowerShot S400 Motherboard Replacement: passo 9, immagine 1 di 2 Canon PowerShot S400 Motherboard Replacement: passo 9, immagine 2 di 2
    • Remove the LCD screen and set it aside.
  10. Canon PowerShot S400 Motherboard Replacement, Motherboard: passo 10, immagine 1 di 1
    • On the main circuit board, gently release the black latches of the four ribbon cables.
    • Gently detach the ribbon cables.
  11. Canon PowerShot S400 Motherboard Replacement: passo 11, immagine 1 di 2 Canon PowerShot S400 Motherboard Replacement: passo 11, immagine 2 di 2
    • Detach the white-capped and green-capped wires, which sit near the flash.
  12. Canon PowerShot S400 Motherboard Replacement: passo 12, immagine 1 di 1
    • Using a spudger, gently detach the shutter button assembly from the camera.
  13. Canon PowerShot S400 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the four 3.5 mm screws that hold the main circuit board.
    • Do not remove the main circuit board yet.
  14. Canon PowerShot S400 Motherboard Replacement: passo 14, immagine 1 di 2 Canon PowerShot S400 Motherboard Replacement: passo 14, immagine 2 di 2
    • Do not completely remove the main circuit board from the camera. A soldered ribbon cable still attaches the board to the camera. Complete removal would break the soldering points.
    • In a hinge-like motion, gently lift the bottom of the main circuit board, which is the side without the soldering points.
    • Gently detach the white ribbon cable from the underside of the main circuit board.
  15. Canon PowerShot S400 Motherboard Replacement: passo 15, immagine 1 di 2 Canon PowerShot S400 Motherboard Replacement: passo 15, immagine 2 di 2
    • Do not attempt this next step unless you have soldering experience and feel comfortable desoldering. Otherwise you may damage the camera.
    • Gently desolder the two ribbon cables attached to the motherboard.
    • Remove the motherboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Ross Bryan
Membro da: 01/21/11
359 Reputazione
3 Guide realizzate
Cal Poly, Team 5-19, Amido Winter 2011 Membro di Cal Poly, Team 5-19, Amido Winter 2011
CPSU-AMIDO-W11S5G19
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,937
