Introduzione
The top panel of the camera grants access to the shutter button and the rotating dial. Removing the top panel is also necessary to access and remove other internal parts.
Cosa ti serve
Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
Turn the camera over on its side so that the terminals are facing you.
Remove the screw (3.9mm, Phillips #00) that is connecting the top panel to the metal frame.
Altre 3 persone hanno completato questa guida.
