Salta al contenuto principale
Canon PowerShot G3 Speaker Replacement
Cosa ti serve
  1. Canon PowerShot G3 Speaker Replacement, Speaker: passo 1, immagine 1 di 1
    • Start to remove the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Speaker Replacement: passo 2, immagine 1 di 1
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Speaker Replacement: passo 3, immagine 1 di 1
    • Next remove the front and right side panels (the left is attached to the front panel).
  4. Canon PowerShot G3 Speaker Replacement: passo 4, immagine 1 di 1
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Speaker Replacement: passo 5, immagine 1 di 2 Canon PowerShot G3 Speaker Replacement: passo 5, immagine 2 di 2
    • The front of the camera should now resemble the picture shown. (Image 1)
    • Remove the capacitor/speaker housing using your finger nail or other thin object to lift it up around the edges. (Image 2)
  6. Canon PowerShot G3 Speaker Replacement: passo 6, immagine 1 di 1
    • To remove the circuit ribbon (brown strip) pull it out of the plastic piece it is connected to.
  7. Canon PowerShot G3 Speaker Replacement: passo 7, immagine 1 di 1
    • You should now be able to see how the capacitor/speaker housing slides out of the frame.
  8. Canon PowerShot G3 Speaker Replacement: passo 8, immagine 1 di 2 Canon PowerShot G3 Speaker Replacement: passo 8, immagine 2 di 2
    • Disconnect the speaker wires from the camera, then use a small flat head screw driver to lift the speaker out of its housing.
    • Order a new speaker from the manufacturer or take it to a local electronics store to see if they have one.
Conclusione
Ryan Riales
Membro da: 10/22/15
201 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 278
