Salta al contenuto principale
Canon PowerShot G12 Rear Function Setting Dial Replacement
Cosa ti serve
  1. Canon PowerShot G12 Rear Function Setting Dial Replacement, Rear Function Setting Dial: passo 1, immagine 1 di 1
    • Remove the three screws on the bottom of the camera using a Phillips-head 00 screwdriver.
    Chiedi a FixBot
  2. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 2, immagine 1 di 1
    • Remove all of the screws on both the left and right side of the camera.
    Chiedi a FixBot
  3. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 3, immagine 1 di 1
    • Looking at the front side of the camera, there is a port on left side of the camera labeled HDMI.
    • Remove the one screw on the side of the HDMI port.
    Chiedi a FixBot
  4. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 4, immagine 1 di 1
    • Remove the screw on the right side of the view finder on the back side of the camera.
    Chiedi a FixBot
  5. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 5, immagine 1 di 1
    • Using a spudger, carefully pry open the back side of the camera starting directly under the camera's serial label.
    • Make sure all sides of the back case are loose before trying to force it off of the camera. It should be removed with relatively little effort.
    Chiedi a FixBot
  6. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 6, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • The back case is still attached to the camera with a yellow ribbon cable. The socket has a black flip-up lid that must be flipped up before the cable can be removed. Use precision tweezers to remove the cable.
    Chiedi a FixBot
  7. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 7, immagine 1 di 1
    • Put the camera aside and look to the interior to the camera's back shell.
    • Peel off the thick, plastic seal over the metal plate near the yellow ribbon cable.
    Chiedi a FixBot
  8. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 8, immagine 1 di 1
    • Remove the four screws from the metal plate using a Phillips-head 00 screwdriver.
    Chiedi a FixBot
  9. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 9, immagine 1 di 1
    • Remove the spring from its socket using precision tweezers allowing the metal plate with the function dial to be removed.
    Chiedi a FixBot
  10. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 10, immagine 1 di 1
    • Using precision tweezers, pry the old function dial out of its socket leaving only a black, metal ring attached.
    Chiedi a FixBot
  11. Canon PowerShot G12 Rear Function Setting Dial Replacement: passo 11, immagine 1 di 1
    • Attach the new function dial simply by pressing it into the black, metal ring until you hear a click.
    Chiedi a FixBot
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 1-5, Leahy Winter 2015 Membro di USF Tampa, Team 1-5, Leahy Winter 2015
USFT-LEAHY-W15S1G5
3 Membri
6 guide realizzate
2Commenti sulla guida
Thank you so much!! I needed to replace the entire rear cover, because Canon doesn't sale just the wheel separately. your guide was the best one I found on the web. I think you ought to make a video of it, I admit I didn't see the "black flip-up" in part 6 so that part (putting the cable back in) was the most aggravating part for me.
But again thank you so much!
Maya Shemolewitz - Rispondi Condividi
Very good guide, the only one I’ve seen so far. Thanks for that>
Philip Knowles
Philip Knowles - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 12
Ultimi 30 giorni: 82
Tutti i Tempi: 4,100
