Salta al contenuto principale
Canon PowerShot G11 Rear Cover Replacement
Cosa ti serve
  1. Canon PowerShot G11 Rear Cover Replacement, Rear Cover: passo 1, immagine 1 di 1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Cover Replacement: passo 2, immagine 1 di 1
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Cover Replacement: passo 3, immagine 1 di 1
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Cover Replacement: passo 4, immagine 1 di 1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Cover Replacement: passo 5, immagine 1 di 1
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Cover Replacement: passo 6, immagine 1 di 1
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Cover Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Cover Replacement: passo 8, immagine 1 di 1
    • The rear cover is now unattached from the camera.
Conclusione
USF Tampa, Team 5-6, Brown Winter 2015 Membro di USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,093
