Salta al contenuto principale
Canon PowerShot ELPH330 HS Camera Case Replacement
Cosa ti serve
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: passo 1, immagine 1 di 2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: passo 1, immagine 2 di 2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: passo 2, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: passo 3, immagine 1 di 1
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: passo 4, immagine 1 di 1
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: passo 5, immagine 1 di 1
    • Using your fingers, carefully pry the case apart at the seam.
Conclusione
Michelle Ngo
Membro da: 07/23/19
595 Reputazione
3 Guide realizzate
UW Tacoma, Team S1-G3, Liner Summer 2019 Membro di UW Tacoma, Team S1-G3, Liner Summer 2019
UWT-LINER-SU19S1G3
4 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 224
