Salta al contenuto principale
Canon PowerShot ELPH 310 HS Shutter Button Replacement
Brandon
Brandon e 3 altri collaboratori
Ultimo aggiornamento il December 24, 2015
20 minuti
Moderato
Foto Azione
Necessarie Più Immagini
Introduzione
Vai al passo 1
The Canon PowerShot Elph 310 HS may have issues with the shutter button sticking. Replacing the button should only take a few minutes with these steps.
Cosa ti serve
Strumenti
  1. Canon PowerShot ELPH 310 HS Shutter Button Replacement, External Panels: passo 1, immagine 1 di 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 2, immagine 1 di 2 Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 2, immagine 2 di 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 3, immagine 1 di 2 Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 3, immagine 2 di 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 4, immagine 1 di 2 Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 4, immagine 2 di 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 5, immagine 1 di 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 6, immagine 1 di 2 Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 6, immagine 2 di 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 7, immagine 1 di 1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS Shutter Button Replacement, Shutter Button: passo 8, immagine 1 di 1
    • Using your hand, lift and remove the shutter button deck from the top of camera.
    • The front clasp is fragile.
  9. Canon PowerShot ELPH 310 HS Shutter Button Replacement: passo 9, immagine 1 di 1
    • Unclip the cables from the front of the motherboard, using your hands.
Conclusione
Brandon
Membro da: 09/24/15
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 536
