Salta al contenuto principale
Canon PowerShot ELPH 310 HS Lens Replacement
Cosa ti serve
  1. Canon PowerShot ELPH 310 HS Lens  Replacement, External Panels: passo 1, immagine 1 di 1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 2, immagine 1 di 2 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 2, immagine 2 di 2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 3, immagine 1 di 2 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 3, immagine 2 di 2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 4, immagine 1 di 2 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 4, immagine 2 di 2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 5, immagine 1 di 1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 6, immagine 1 di 2 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 6, immagine 2 di 2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 7, immagine 1 di 1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS Lens  Replacement, LCD Screen: passo 8, immagine 1 di 2 Canon PowerShot ELPH 310 HS Lens  Replacement, LCD Screen: passo 8, immagine 2 di 2
    • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
  9. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 9, immagine 1 di 1
    • Using your hands, lift up the screen.
    • The screen is fragile!
  10. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 10, immagine 1 di 3 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 10, immagine 2 di 3 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 10, immagine 3 di 3
    • The strip tears easily!
    • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
    • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
  11. Canon PowerShot ELPH 310 HS Lens  Replacement, Lens: passo 11, immagine 1 di 2 Canon PowerShot ELPH 310 HS Lens  Replacement, Lens: passo 11, immagine 2 di 2
    • On the front motherboard, unscrew the one bottom right 3 mm Phillips head screw.
  12. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 12, immagine 1 di 3 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 12, immagine 2 di 3 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 12, immagine 3 di 3
    • Unscrew the four 3 mm Phillips head screws attached to the metal casing on the back of the camera, behind where the LCD screen once was.
  13. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 13, immagine 1 di 2 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 13, immagine 2 di 2
    • Using your hands, carefully lift the flash housing up and remove it from the area.
  14. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 14, immagine 1 di 1
    • Using a plastic spudger, remove the bottom front ZIF connector.
  15. Canon PowerShot ELPH 310 HS Lens  Replacement: passo 15, immagine 1 di 2 Canon PowerShot ELPH 310 HS Lens  Replacement: passo 15, immagine 2 di 2
    • Using your hands, carefully remove the center ribbon.
    • Manually remove the lens.
Conclusione
Altre 4 persone hanno completato questa guida.
Un commento
excellent procedure. nice pix too. hint about those fragile flex cables is important, they are thinner than a human hair!
Happy Fixer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,292
