Introduzione
The Canon PowerShot ELPH 310 HS may experience some damage to the outer casings. If you need to remove the outer casings to replace another component, or need to replace the outer casing, follow this guide.
Cosa ti serve
Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
Using your hands, remove the image stabilizer panel.
Un commento
I have lost the two 4mm screws from the bottom of the camera and would like to buy replacements. Does anyone know the exact size of these screws?
