Salta al contenuto principale
Canon PowerShot ELPH 150 IS Battery Replacement
  1. Canon PowerShot ELPH 150 IS Battery Replacement, Battery: passo 1, immagine 1 di 2 Canon PowerShot ELPH 150 IS Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Safety First: Power off your device. Locate the On/Off button.
  2. Canon PowerShot ELPH 150 IS Battery Replacement: passo 2, immagine 1 di 1
    • Hold button down firmly until the screen goes dark and the camera is powered off.
  3. Canon PowerShot ELPH 150 IS Battery Replacement: passo 3, immagine 1 di 1
    • Locate the Battery door which is marked, "CARD/BATT OPEN"
  4. Canon PowerShot ELPH 150 IS Battery Replacement: passo 4, immagine 1 di 1
    • Press the door down with your thumb and slide to the right until you hear a click. This means the door has unlocked and will open.
  5. Canon PowerShot ELPH 150 IS Battery Replacement: passo 5, immagine 1 di 1
    • With the door open, locate the orange clip near the edge of the camera. This clip is holding the battery in place.
  6. Canon PowerShot ELPH 150 IS Battery Replacement: passo 6, immagine 1 di 1
    • Press the orange clip back towards the back plate to release the battery.
  7. Canon PowerShot ELPH 150 IS Battery Replacement: passo 7, immagine 1 di 1
    • The battery should pop out easily and you can simply remove the battery from its housing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 488
