Introduzione
Use this guide to replace the Canon PowerShot A75's upper motherboard.
Cosa ti serve
Remove the 4.4mm screw directly behind the eyepiece on the top of the camera.
Remove the 4.3mm screw to the right of the eyepiece housing in the crack in between the eyepiece and a ribbon cable on top of the camera.
Locate the white cable on top of the camera where the eyepiece was.
Using tweezers, grasp the white cable as close to the connection point as possible and gently remove the cable.
Remove the 2.9mm screw directly underneath the white cable.
Remove the 3.5mm screw found near the capacitor and the flash unit.
