Salta al contenuto principale
Canon PowerShot A630 Front Panel Replacement
Cosa ti serve
  1. Canon PowerShot A630 Front Panel Replacement, Front Panel: passo 1, immagine 1 di 2 Canon PowerShot A630 Front Panel Replacement, Front Panel: passo 1, immagine 2 di 2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Front Panel Replacement: passo 2, immagine 1 di 2 Canon PowerShot A630 Front Panel Replacement: passo 2, immagine 2 di 2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Front Panel Replacement: passo 3, immagine 1 di 1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Front Panel Replacement: passo 4, immagine 1 di 2 Canon PowerShot A630 Front Panel Replacement: passo 4, immagine 2 di 2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Front Panel Replacement: passo 5, immagine 1 di 2 Canon PowerShot A630 Front Panel Replacement: passo 5, immagine 2 di 2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Front Panel Replacement: passo 6, immagine 1 di 1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Front Panel Replacement: passo 7, immagine 1 di 2 Canon PowerShot A630 Front Panel Replacement: passo 7, immagine 2 di 2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
Clemson, Team 2-5, Benson Fall 2014 Membro di Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 793
