Cosa ti serve
Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
Remove batteries.
Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
There are 2 screws at the other side that need to be removed before you can seperate the front panel
Use the spudger to gently pull back the retaining clip and pull the ribbon out.
The top panel should now be completely detached from the camera.
