Salta al contenuto principale
Canon PowerShot A620 Camera Housing Replacement
Cosa ti serve
  1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, immagine 1 di 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, immagine 2 di 3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: passo 1, immagine 3 di 3
    • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
  2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: passo 2, immagine 1 di 2 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: passo 2, immagine 2 di 2
    • Insert AA batteries according to the diagram printed on the camera.
    • Close the battery door.
  3. Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, immagine 1 di 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, immagine 2 di 3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: passo 3, immagine 3 di 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  4. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: passo 4, immagine 1 di 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  5. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: passo 5, immagine 1 di 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  6. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 6, immagine 1 di 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 6, immagine 2 di 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  7. Canon PowerShot A620 Camera Housing Replacement, Top Panel: passo 7, immagine 1 di 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  8. Canon PowerShot A620 Camera Housing Replacement, Front Panel: passo 8, immagine 1 di 2 Canon PowerShot A620 Camera Housing Replacement, Front Panel: passo 8, immagine 2 di 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  9. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 9, immagine 1 di 2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: passo 9, immagine 2 di 2
    • Gently pull the terminal cover to separate it from the camera.
  10. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: passo 10, immagine 1 di 2 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: passo 10, immagine 2 di 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  11. Canon PowerShot A620 Camera Housing Replacement, Back Panel: passo 11, immagine 1 di 2 Canon PowerShot A620 Camera Housing Replacement, Back Panel: passo 11, immagine 2 di 2
    • Gently pull the back panel to separate it from the camera.
Conclusione
Altre 2 persone hanno completato questa guida.
Jaime Abraham
Membro da: 09/08/14
350 Reputazione
3 Guide realizzate
CSU Fullerton, Team 1-1, Bruce Fall 2014 Membro di CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Membri
6 Guide realizzate
Un commento
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,782
