Introduzione
This guide will instruct you how to remove the front and back covers from the camera and disassemble the flash in order to replace or repair it.
Parti
Nessuna parte specificata.
  1. The battery hatch is on the bottom of the camera. CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
    • This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
    • The clock battery cover is shown here in the purple circle. Use a fingernail to lift the battery out of the camera.
  3. When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
    • Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
  5. Remove the two screws located on the other side of the camera using a magnetic screwdriver
    • Remove the two screws located on the other side of the camera using a magnetic screwdriver
  6. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  7. Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
    • Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
  8. Open the battery cover.
    • Open the battery cover.
    • Using the iPod tool, push up gently around all edges of the camera.
  9. Press and hold down the button shown in the blue circle.
    • Press and hold down the button shown in the blue circle.
    • While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
  10. Remove the front cover of the camera. This may require a bit of force.
    • Remove the front cover of the camera.
    • This may require a bit of force.
  11. Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
    • Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
    • Lift the black plastic covering off the circuit board.
  12. Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
    • Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
    • The clear flash lens may fall out. Do not worry this will not affect the camera and can easily be placed back in its spot.
  13. Unsolder the cables under the circuit board.
    • Unsolder the cables under the circuit board.
  14. The flash logic board can now be removed from the camera and replaced.
    • The flash logic board can now be removed from the camera and replaced.
Conclusione
Altre 3 persone hanno completato questa guida.
Zach
Membro da: 11/10/2010
269 Reputation
6 Guide realizzate
Cal Poly, Team 9-19, Regan Fall 2010 Membro di Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Membri
7 Guide realizzate
Zach, can you show how to replace the Ring Release Button? The release button appears to be fixed to the front cover once it is removed. Can we purchase a replacement release button?
Jae Ennis - Replica
If it is the flash element that needs to be replace, I presume I will see it when I’m there.
Is this correct ?
effitech_structure@yahoo.com
Jean-François Rondeau - Replica
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 15,069
