Salta al contenuto principale
Canon PowerShot A590 IS Back Cover Replacement
Cosa ti serve
  1. Canon PowerShot A590 IS Back Cover Replacement, Batteries: passo 1, immagine 1 di 2 Canon PowerShot A590 IS Back Cover Replacement, Batteries: passo 1, immagine 2 di 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Back Cover Replacement: passo 2, immagine 1 di 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Back Cover Replacement: passo 3, immagine 1 di 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Back Cover Replacement, Back Cover: passo 4, immagine 1 di 1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot A590 IS Back Cover Replacement: passo 5, immagine 1 di 1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Canon PowerShot A590 IS Back Cover Replacement: passo 6, immagine 1 di 1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Canon PowerShot A590 IS Back Cover Replacement: passo 7, immagine 1 di 1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
Conclusione
Altre 7 persone hanno completato questa guida.
Zach
Membro da: 10/11/10
281 Reputazione
6 Guide realizzate
Cal Poly, Team 9-19, Regan Fall 2010 Membro di Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Membri
14 Guide realizzate
Un commento
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 8,547
