Introduzione
This guide will give a step by step procedure of how to access and replace the SD card reader in the Canon PowerShot A550
Parti
Nessuna parte specificata.
Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Remove two 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
Loosen the black ribbon clamp using an iPod opening tool
Release the LCD screen by removing the ribbon from the body of the camera.
Release the black ribbon clamp using an iPod opening tool to lift it.
Remove the ribbon connecting the circuit board from the body of the camera using tweezers.
The SD card reader is attached to the back of the circuit board. The circuit board and SD card combination should be replaced.
