Salta al contenuto principale
Canon PowerShot A540 SD Card Reader Replacement
Cosa ti serve
  1. Canon PowerShot A540 SD Card Reader Replacement, Back Cover: passo 1, immagine 1 di 2 Canon PowerShot A540 SD Card Reader Replacement, Back Cover: passo 1, immagine 2 di 2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 SD Card Reader Replacement: passo 2, immagine 1 di 1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 SD Card Reader Replacement: passo 3, immagine 1 di 1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 SD Card Reader Replacement: passo 4, immagine 1 di 1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 SD Card Reader Replacement: passo 5, immagine 1 di 3 Canon PowerShot A540 SD Card Reader Replacement: passo 5, immagine 2 di 3 Canon PowerShot A540 SD Card Reader Replacement: passo 5, immagine 3 di 3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 SD Card Reader Replacement, SD Card Reader: passo 6, immagine 1 di 2 Canon PowerShot A540 SD Card Reader Replacement, SD Card Reader: passo 6, immagine 2 di 2
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
  7. Canon PowerShot A540 SD Card Reader Replacement: passo 7, immagine 1 di 2 Canon PowerShot A540 SD Card Reader Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
  8. Canon PowerShot A540 SD Card Reader Replacement: passo 8, immagine 1 di 3 Canon PowerShot A540 SD Card Reader Replacement: passo 8, immagine 2 di 3 Canon PowerShot A540 SD Card Reader Replacement: passo 8, immagine 3 di 3
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
  9. Canon PowerShot A540 SD Card Reader Replacement: passo 9, immagine 1 di 2 Canon PowerShot A540 SD Card Reader Replacement: passo 9, immagine 2 di 2
    • Remove the two (2) 3.0 mm screws shown with the Phillips head #000 screwdriver.
  10. Canon PowerShot A540 SD Card Reader Replacement: passo 10, immagine 1 di 2 Canon PowerShot A540 SD Card Reader Replacement: passo 10, immagine 2 di 2
    • Remove the ribbon from the clamp/bar securing it by using your tweezers to pull the bar up.
  11. Canon PowerShot A540 SD Card Reader Replacement: passo 11, immagine 1 di 1
    • Remove the SD Card reader and replace.
    • There is another metal bar that comes off of the SD Card reader when screws are removed.
Conclusione
Altre 2 persone hanno completato questa guida.
Cooper Hale
Membro da: 03/22/15
556 Reputazione
3 Guide realizzate
Baylor, Team 7-12, Williams Spring 2015 Membro di Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,226
