Salta al contenuto principale
Canon PowerShot A540 LCD Screen Replacement
Cosa ti serve
    1. Canon PowerShot A540 LCD Screen Replacement, Back Cover: passo 1, immagine 1 di 2 Canon PowerShot A540 LCD Screen Replacement, Back Cover: passo 1, immagine 2 di 2
      • Turn off the camera.
      • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon PowerShot A540 LCD Screen Replacement: passo 2, immagine 1 di 1
      • Turn the camera upside down to view the "Card/Batt. Open" Cover.
      • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon PowerShot A540 LCD Screen Replacement: passo 3, immagine 1 di 1
      • Open "Card/Batt. Open" Cover.
      • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon PowerShot A540 LCD Screen Replacement: passo 4, immagine 1 di 1
      • Turn the camera to the right side of the LCD screen.
      • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    5. Canon PowerShot A540 LCD Screen Replacement: passo 5, immagine 1 di 3 Canon PowerShot A540 LCD Screen Replacement: passo 5, immagine 2 di 3 Canon PowerShot A540 LCD Screen Replacement: passo 5, immagine 3 di 3
      • Gently remove the back cover.
      • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
      • Then move onto the other edges and the top.
      • It may be tight at the top!
      Chiedi a FixBot
      Aggiungi Commento
    1. Canon PowerShot A540 LCD Screen Replacement, LCD Screen: passo 6, immagine 1 di 2 Canon PowerShot A540 LCD Screen Replacement, LCD Screen: passo 6, immagine 2 di 2
      • Turn the camera to view the back.
      • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
      • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon PowerShot A540 LCD Screen Replacement: passo 7, immagine 1 di 2 Canon PowerShot A540 LCD Screen Replacement: passo 7, immagine 2 di 2
      Strumento utilizzato in questo passaggio:
      • Lift the LCD Screen off of the back to view the attached ribbon cables.
      • Use tweezers to flip the black bar up.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon PowerShot A540 LCD Screen Replacement: passo 8, immagine 1 di 3 Canon PowerShot A540 LCD Screen Replacement: passo 8, immagine 2 di 3 Canon PowerShot A540 LCD Screen Replacement: passo 8, immagine 3 di 3
      • Gently pull the big ribbon out.
      • Gently pull the small ribbon out.
      • The small ribbon does not have a bar like the big ribbon.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon PowerShot A540 LCD Screen Replacement: passo 9, immagine 1 di 2 Canon PowerShot A540 LCD Screen Replacement: passo 9, immagine 2 di 2
      • Use tweezers at the top left of the LCD Screen to wedge the top left of the Outer Frame loose.
      • Use your thumb to hold the Outer Frame open.
      • Use the tweezers at the top right of the LCD Screen to wedge the top right of the Outer Frame loose.
      Chiedi a FixBot
      Aggiungi Commento
    5. Canon PowerShot A540 LCD Screen Replacement: passo 10, immagine 1 di 2 Canon PowerShot A540 LCD Screen Replacement: passo 10, immagine 2 di 2
      • Slide the LCD Screen out from the Outer Frame.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team 7-12, Williams Spring 2015 Membro di Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Membri
20 guide realizzate
1Commento della guida
I wish to purchase a new screen. Where? I feel capable of repair per these instructions and a u tube video.
Geo Schou - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 38
Tutti i Tempi: 1,586
