Introduzione
This guide will involve complete disassembly of the camera.
Cosa ti serve
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
Remove the six 2mm Phillips #00 screws that are located under the motherboard.
Altre 3 persone hanno completato questa guida.
Un commento
please put a big warning note on the step after removing the blue tape from the lens. and the next on is where you lift something on the mother board with a spluger..something like that. well i used a screwdriver and got such a big electrical shock.... scared the crapola out of me. please make a note .... can get electrical shock....
