Salta al contenuto principale
Canon PowerShot A2300 SD Card/Battery Door Replacement
  1. Canon PowerShot A2300 SD Card/Battery Door Replacement, SD Card/Battery Door: passo 1, immagine 1 di 1
    • Open the Card/Battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
  2. Canon PowerShot A2300 SD Card/Battery Door Replacement: passo 2, immagine 1 di 1
    • Move card/battery latch to 90 degrees.
  3. Canon PowerShot A2300 SD Card/Battery Door Replacement: passo 3, immagine 1 di 1
    • Gently rotate latch 90 degrees either clockwise or counterclockwise then remove it.
Conclusione
Baylor, Team 7-14, Williams Spring 2015 Membro di Baylor, Team 7-14, Williams Spring 2015
BU-WILLIAMS-S15S7G14
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 30
Tutti i Tempi: 772
