Salta al contenuto principale
Canon PowerShot A2200 Button Assembly Replacement
Cosa ti serve
  1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: passo 1, immagine 1 di 1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Button Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Button Assembly Replacement: passo 3, immagine 1 di 1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Button Assembly Replacement: passo 4, immagine 1 di 3 Canon PowerShot A2200 Button Assembly Replacement: passo 4, immagine 2 di 3 Canon PowerShot A2200 Button Assembly Replacement: passo 4, immagine 3 di 3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Button Assembly Replacement: passo 5, immagine 1 di 3 Canon PowerShot A2200 Button Assembly Replacement: passo 5, immagine 2 di 3 Canon PowerShot A2200 Button Assembly Replacement: passo 5, immagine 3 di 3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
  6. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: passo 6, immagine 1 di 2 Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: passo 6, immagine 2 di 2
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
  7. Canon PowerShot A2200 Button Assembly Replacement: passo 7, immagine 1 di 1
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
Conclusione
Benjamin Gee
Membro da: 03/31/15
983 Reputazione
5 Guide realizzate
Baylor, Team 4-5, Williams Spring 2015 Membro di Baylor, Team 4-5, Williams Spring 2015
BU-WILLIAMS-S15S4G5
4 Membri
13 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 869
