Salta al contenuto principale
Canon PowerShot A200 LCD Display Replacement
Cosa ti serve
  1. Canon PowerShot A200 LCD Display Replacement, Canon PowerShot A200: passo 1, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two screws located at the bottom of the camera.
  2. Canon PowerShot A200 LCD Display Replacement: passo 2, immagine 1 di 2 Canon PowerShot A200 LCD Display Replacement: passo 2, immagine 2 di 2
    • Locate the screw and the rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
    • Remove the two screws with the Phillips #00 screwdriver.
  3. Canon PowerShot A200 LCD Display Replacement: passo 3, immagine 1 di 2 Canon PowerShot A200 LCD Display Replacement: passo 3, immagine 2 di 2
    • Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
    • Be sure to remove the memory card.
    • Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
  4. Canon PowerShot A200 LCD Display Replacement: passo 4, immagine 1 di 2 Canon PowerShot A200 LCD Display Replacement: passo 4, immagine 2 di 2
    • Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
    • Remove the two visible screws with the Phillips #00 screwdriver.
    • During reassembly, the holes for these screws must align properly with the interior of the camera body. Then the black battery cover must lie flat and be held in place by the grey tab.
  5. Canon PowerShot A200 LCD Display Replacement: passo 5, immagine 1 di 2 Canon PowerShot A200 LCD Display Replacement: passo 5, immagine 2 di 2
    • Remove the screen battery located to the left of the screen.
    • Set the screen battery aside for reassembly
  6. Canon PowerShot A200 LCD Display Replacement: passo 6, immagine 1 di 2 Canon PowerShot A200 LCD Display Replacement: passo 6, immagine 2 di 2
    • Gently pull the camera apart from the top.
    • Be careful. The two halves are still attached by two short ribbons at the bottom of the camera.
  7. Canon PowerShot A200 LCD Display Replacement: passo 7, immagine 1 di 2 Canon PowerShot A200 LCD Display Replacement: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Locate the black tabs on either side of the white ribbon.
    • Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
    • Gently pull the white ribbon out from its connection.
  8. Canon PowerShot A200 LCD Display Replacement: passo 8, immagine 1 di 3 Canon PowerShot A200 LCD Display Replacement: passo 8, immagine 2 di 3 Canon PowerShot A200 LCD Display Replacement: passo 8, immagine 3 di 3
    • Locate the black tabs on either side of the orange ribbon.
    • Gently pull the orange ribbon out of its connection.
    • Your camera will now be in two separate pieces.
  9. Canon PowerShot A200 LCD Display Replacement, LCD Display: passo 9, immagine 1 di 1
    • Use a Phillips head screwdriver to remove the four screws from the corners of the LCD.
  10. Canon PowerShot A200 LCD Display Replacement: passo 10, immagine 1 di 1
    • Use the iFixit plastic opening tool to lift the LCD away from the back case.
    • The LCD will still be attached to the back of the camera case by an orange strip.
  11. Canon PowerShot A200 LCD Display Replacement: passo 11, immagine 1 di 1
    • Use a soldering iron to remove the LCD from the orange cable connected to the back of the camera.
    • Use the soldering iron to attach your new LCD in place.
    • Caution: When soldering, allow enough slack in the orange cable, so the LCD will lie flat. The white bar will lie parallel with the electronic components embedded in the motherboard.
Conclusione
Follow the instructions in the prerequisite guide Disassembling the Canon PowerShot A200 Case.
Once completed, proceed with installing a new LCD Display.
Jeff Barich
Membro da: 01/28/11
101 Reputazione
1 Guida realizzata
Cal Poly, Team 7-37, Regan Winter 2011 Membro di Cal Poly, Team 7-37, Regan Winter 2011
CPSU-REGAN-W11S7G37
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,102
